V8 PT Cruiser
Thanks I dont suposse you saved the original photo's did you.
Or has anyone else saved the photo's somewhere.
Just the one of the engine bay gave me more go to get this done.
Is the lexus LS400 the same floorpan as the Soarer dont see many Soarer's over here.
photos
Soarer is a Lexus coupe
Have photos here is some more
more photos
some more long nites
front suspension
Used the chassis rails and strut towers from the soarer and grafted it into the PT uses front alloy x beam a arms engine mounts just used some Supra platforms to get ride hight lower
rear done the same grafted rear towers and chassis rails uses diff and standard toyota subframe withs suspension
Turbo set up
Photos of engine turbo
Turbo goes where alternator was
alternator remounted in front of engine
Good work getting all of that under the hood of your PT. I have no excuse not to turbo my UZ now. :rolleyes: Excellent work. I'm sure you are happy with 10psi. Is that the boost level you leave it set at all the time? Are you happy with the size of your intercooler? That's the best PT Cruiser I have ever seen.
intercooler
Intercooler worked fine one the road but arround town and waiting in the heat at the drag strip it increased the temp for a short time
have changed to a water/air cooler which i run a ice tank for drags or a
rad and fan for the road
the shorter piping makes the biggest diff not that it needed any more power down low
run 10lbs all the time have to controll boost with the foot
no point in having adjustable as it tuned to take it and when u want the power its there
front suspension
No the LS is a pig of a thing to remount into another car
SC400 is same as soarer also components shared Supra 80 series
all mounts are of the alloy X member so all thats needed is a strut tower and sway bar mounts
