Chunners32
- 17
- Townsville, QLD
Hi guys,
I am newbie and just brought a UCF11 Celsior that needs a few things fixed. I've done several searches to try and find the answers to my questions but any additional info/advice would be much appriciated.
Here is what i would like help with:
1. What year was my car built? (to help with the other Q's)
2. I need to replace my AC compressor. What are the differences between the 90-93 models? Would a UCF10 compressor be a direct fit?
I've removed the label from my current compressor but some of the numbers are faded/removed. The numbers i can make out are:
DENSO
10PA 447200-???
R134a ?? OIL
I searched on a DENSO website i found the following model numbers:
1990-92 # 471-1219
1993-94 # 471-1162
These do not seem to match what i've got. Any ideas where i can source a cheap replacement compressor?
3. The speedo doesn't work. I believe its the sensor on the back of the gearbox (SP2) as the O/D OFF light flashes. The gearbox still changes gears normally. Is there a difference in the sensors between the year models? No local wreckers in townsville have them so i want to make sure i order the right part from a brisbane wrecker.
4. The tacho doesn't work properly. It sits dead (as low as the needle will go) while driving until you give it some. When the engine is high in the revs the needle only indicates around the 1,000-1,500 rpm mark. Is it most likely that the needle has slipped off the shaft and needs to be re-calibrated? or is it more of a sensor issue? What are the other possible causes?
Any help would be great.
Cheers,
Tristan
DENSO
10PA 447200-???
R134a ?? OIL
1990-92 # 471-1219
1993-94 # 471-1162
Cheers,
Tristan
