shifty biscuits
- Messages
- 31
- Location
- england
i have a 97 ls400 1uz fitted into a 91 toyota gx81 mark II. ecu is the 34/22/16/28 pin pt no 89661-50350
my mate and i have wired it into the car and got it running. i have been over and triple checked the wiring we have done and according to all the info and diagrams i have managed to get hold of it should be right. the relay set up is as the ls400 diagrams, efi relay turns on from ignition, powers up the cir open relay then that powers up the fuel pump relay.... in the diagrams there is a control wire "fc" from pin 4 of the 16 pin ecu plug, its green with black stripe. this should from what i can gather trigger the circuit open relay by being an ecu switched earth? the wire has no signal and this relay is not operating, therefore the fuel pump relay is not operating either. could the ecu be damaged? im sure this wire used to earth out on ign, the relays all worked a few weeks ago although one of them clicked loads when the car was running...
on to the starting prob/missfire.
we have been running the fuel pump with a switch to get it going. the car has never been able to idle from cold start, it takes a while before it will hold idle on its own. in the ls400 it was fine. this problem has now got worse, starting the car is a bitch and it pops and coughs through the intake then when you get it running with the throttle, when running its missing loads and wont rev properly, tending to cut out when you poke at the throttle. after a while it used to sort its self out then it would rev fine and idle smoothly, then it would start fine when warm. today i tried it an the missfire was more persistant and the car was overfuelling loads. so much so i had to give up and shut it off as the fumes filled the unit. its very cold at the moment which i thought might be making it worse. i tested the ecu temp sensor and i think its working ok. problem was the same with this unplugged too.
i have run the car up to temperature twice (a couple of weeks ago) both times it was running fine after the initial cold starting complaints, it would rev and idle perfectly, after 10 or 15 mins the revs would start to drop off and if you held the throttle it was ok but if you left it it would cut off.
could these the fact i dont have any lambda sensors wired up or installed yet be causing me problems? i will be getting some bosses so i can weld them on to my exhausts soon but at the mo they are off.
i have a warlbro 255 lph pump installed but im using the stock fpr. could this cause overfuelling?
im not sure what to try next with these so if anyone can suggest what i could do or try i would be much obliged.
cheers.
cheers.
