removal of manifold sensors
dean
hobart.
hey guys have finaly got my 1uz running but have removed sensors and am wondering what can be done to get it idling again, have been told i need to re connect the IAC, but i have removed the two sensors that have alot of vacum hoses attached, i have no idea what they do exactly,
( located on the right looking at the motor front on )
i have also blocked of where the rocker breather is my engine is a 92 from a celsior. any help on sensors and mods and etc will be helpful, yes a aftermarket ecu would be the go but, not going down that road at the moment thanks :)
I always run the PCV valve and engine breather. No issue to remove the Purge solenoid if you fuel tank has a different breather system. Are you running a 20 series motor with a vaccumm solenoid for the fuel pressure regulator?
Pm me your email so I can email u some photos of my engine all I know is that it's. A 92 model out of a celsiour. Its in a Toyota hilux conversion
