White ls400 New Member Nov 5, 2008 #1 Does anyone know what radiators are interchangable like for example will soarer or supra radiators fit a ls400 and do the automatic lines match up to the radiator bosses
1uzvl New Member Nov 6, 2008 #2 Supra ones are 25mm shorter in core height but mounts look very similar.Obviously the supra one has a filler neck for a pressure cap and ls400 dont.
XR8tt Active Member Nov 6, 2008 #3 You could fit a seperate trans cooler, cool by air ?? Not run ATF through radiator..
