961uz4b
- Messages
- 42
- Location
- Sydney. Northern beachs
I started my 1uz for the first time yesterday, today after connecting the tacho I noticed it was idling very high, around 1500-rpm and did not drop back down once up to running temp.
I tried crimping the hose to the ISC and it immediately brought the engine back down to around 550-rpm
So i took the ISC off the inlet manifold, sprayed it with carby cleaner and compressed air, then put 12v to the appropriate pins to test the valve as described in the ISC system pdf on this site.
It did not move very much at all, in fact i couldn't even see it move inside but it sounded like it was trying to.
I put the ISC back on the engine and ran it now the motor will not idle at all, you need to hold the throttle open or it dies.
Im wondering if my ISC valve is stuffed or there is a wiring problem. I read on here somewhere that there is a way to test if the ISC is getting power through the diagnostics terminal?
Any thoughts?
Any thoughts?
