my heater is going out sc400
Warm Pudgy
bad timing too cause its cold
but heres some symptoms:
the engine does not cool off, so i dont think the therm is stuck
if i hit the knob so it turns to auto while the engine is warm, the lcd turns on but the fans dont blow
like if it were just turned on, and the engine hadn't warmed up yet
if i turn it off auto, the fans turn on but blow out cold air
:banghead:
Inspect the heater valve inside the engine bay on the firewall to see if it is engaging when you turn the temperature control from cold to hot
ill check that out on my next day off
but another thing it does is when the rpm's are high ie: while driving it blows hot air...most times
but while idling just cold air
think the water pump is going out?
