Now when driving the car, at low RPM it feels as though the power steering just dosnt assist at all, so when turning, the steering wheel sticks briefly, which i have to manually pull around to centre or ot straighten the car up...
My question is: could reducing the size of the pulley on the pump help solve this issue if the pump itself isnt damaged..?
next question, then - on LX180's behalf..
Are the pumps essentially the same between the varying models the 1UZ's came out of?
LX180, what model is your 1UZ out of?
OK so far..... and i believe the motor is out of a Crown, as it had a mid bowl sump... but i will have to get back to you to 100% confirm that
When going around corners at speed (ie not from a stopped start) the steering isnt too bad, i know it is in need of a wheel alignment.
But when turning right for example, at a T-Intersection, half way around the corner, i half to manually assist the steering wheel to centre, or if i break traction in first gear, it feels as though its a non power assisted steering car....
Suspension wise i have Brand new Gas Shocks and lowered King Springs.. No coilovers.
