IT'S ALIVE !!!! 1uz into 1991 4Runner Manual
GhostRunner
1990 UCF11 ECU (Early LS400)
Well,
After only taking 5 hours to patch the ECU to the 2 connectors
IH1 and IH2, I was greeted to the sound of a 1uz firing up with no exhaust on it.
Nearly put half of Tathra into panic mode. LOL
Scared the crap out of me and my mate too.
I was rather pleasantly surprised how easy it is. :rolleyes:
That was after about 10 Hours of research and a rather Big Thanks to a member on here.
I fixed the oil level code. It was the only one. Yet... ;)
Now the real work starts on all the fiddly bits to really tidy things up.
I have a question.
I have installed a 100 amp relay between the key crank to starter so that I can wire in a clutch safety switch. That will have an over ride rocket style switch in case I get stuck with one of those pesky hill starts and also stop any accidental key starts.
Or unwanted :)
What way would you wire the NSW and STA inputs?
I have the STA on the output side of the relay then the NSW on the input.
I think this will be fine but I would like some constructive criticism on this setup.
Me myself thinks that the NSW should be on the hot when start side.
Dunno, What do you guy's think. ?
It is working but I am just being fussy.:cool:
Ya bein' fussy Doug!
I would run the NSW and clutch switch between the start contact on the IGN switch and the relay input.
That way you are not running starter sol current through the clutch and neutral switches.
