Idle Control
redsunbeam
All of the inlet manifolds for roots type superchargers i have looked at dont have provision for the idle control motor. Bullet can add this at extra cost. If it isnt added, how is the idle controlled?
I guess ive answered my own question, if its not on the manifold it has to be moved to the inlet pipe anywhere after the MAF sensor??
Just incase you or others find this helpfull. It depends on if you are still useing the stock engine management or stand alone. I have my 1uz running on mega squirt. I did install the stock IAC unit on the inlet to the supercharger. How ever I have not yet gotten it to work with the mega squirt. So the MS2 is controling my idle. I adjusted the stop on the throtlebody to keep the idle from dropping below 750 rpm "ish" and other then realy cold days or high electrical draw (headlights, fogs, wipers, turn signal, heat on high all at once) its normally just fine.
