makaveli200369
- 26
- Oxnard CA
For early 90's cars that have fuel injection but still have a distributor how in the world does the ECU control ignition timing? There was no vacumm or electronic devices in the distributor that allowed it to move around. And if the ECU retarded or advanced when it sends the signal to fire the one main coil I do see how it would sych up with the rotor/cap and points.
Meaning lets say its a 6 cylinder distributor and every 60 degrees the rotor connects each cylinder to the main coil as it spins around. If you retarded or advanced the ignition timing from the coil...the rotor could be delayed or advanced past the time window which it has the ability to transfer the electricity from the rotor to the points.
I must be missing something...
