Found the problem in my car!!!!!!!!!!!!!!!!!!!
Sorry i took so long finally got the car back today its been to two different auto electicians. Turns out the wiring loom had been dammaged. Inside the drivers side wheel arch there is a wiring loom that runs above the tire it is encased in a plastic pocket type case. For some reason my tyre has been rubbing on this case when going over bumps and has been eating away at the case and then the wires inside it. The effect was 17 exposed wires all touching each other, the fact that nothing more serious happend is a godsent. Next stage is to get the air suspension checked cause it really shouldnt be touching around that area. I hope this helped you, cost me 100 dollars for them to find it and i fixed it myself using shrink wrap and solder. Will probably cost alot more than that to get air suspension good again!!!!!!!!!
