HELP: sc400 air sus dont work
tdcoup
as the tittle sez iv got a sc400 and the air suspension doest do anything when i change to sports mode and it seems to be siting to high and wobles around alot and it doest handle to well. any ideas wats going on?
p.s any1 know if the ls400 aftermarket hight controler will work in a sc400?
hi tdcoup, have you tried turning it off in the boot there is a switch on the passenger side, sounds like the sensors are confused, turn it off, disconnect the car battery for 1/2 hour and retry, will it select low postion, ie release the air from the system, or does the pump start up and then pump it to max height.
Regards
Lambo
The height controller for the LS400 won't work in a Soarer.
Any improvement after disconnecting the battery?
um ill try that thanks nah it dosnt lower down not evan when u turn the car off all day just sits up high all the time looks fuking ****
never herd the air pump start
Hi Tdcoup , has the car been on a lift recently, if so you must turn off the air suspension with the boot switch before lifting it up. if not all the wheel sensors travel outside their normal range, if the car is up at the max and you press down what happens, if nothing check the fuse in the fuse box, maybe there is no supply volts to the system, maybe the pump raised the car and then the fuse blew, if you push the down switch it should switch on the air discharge soloniod to alow the air out of the system.
Regards
Lambo
