Fuel pump relays
Big
As title says..is this the most easiest/simplest way to wire up and run a fuel pump along with the resistor..I have one of those at 0.75 ohms..?(sideshow has mentioned this many times..)mainly why i'm asking is that I'm not sure i can aford a fuel pump ecu to run it..and i have about 3 relays floating around here..seeing as i think my intank pump will be here tomorrow i'd like to get it running if i can in the next day or so..then i'd be gettin real excited..lol still have to wire up the dash yet..haha:fing02:
cheers Keri
What engine and ECU are you running.
There are different solutions depending on Crown of LS400/Soarer.
The Soarer I can't help with but I'm sure someone else will have the answer.
Be patient.
soarer has fpump ecu
just do what i said
lpg tahcometric relay i sell for 35 bucks
this primes pump relay any normal relay for 2 seconds when ign turns on
then it turns off
then it will only turn on relay when there is an rpm from the ig- wire which comes from igniter
so for 40 bucks u can run a tacho relay triggering a normal bosch relay which powers the fuel pump
alot fo race cars run these for safety
instead of the tight asses and dodgey brothers who run fpump off ignition
any toyota that has fuel pump ecu i run these
and any car that gets modified i never ever run the 2 speed fuel pmp
incase they do more mods and they need the more voltage to the pump
ive used these on over 100 cars and never had a prob
then it turns off
Thansk sideshow..gloverman is sending me the fuel pump ecu etc so i should be able to use that more effectively or at least as factory had intended it to be..if i have any probs i'll be trying to get one of those relays but i did try some what a couple days ago and by the puzzled look on everyones face I'm guessing they haven't heard of it..LOL go figure..this is the 21st century right..?i'll keep ya posted..thanks for the advice..Cheers Keri
