Fan relocation in sc400
What is the model number of the flex-a-lite fan fan that was installed, my sc oem fan recently fell off. I have been looking for an electric fan but do not know anything about the cfm's or if i could replace it with a dual electric fan until i joined the forum.
Flex-a-lite fans are expensive. I bought a pair of 12" fans on Ebay and they work just so perfect. With a pair of seperate fans, you can locate at any position that you like. Make sure you run 2 seperate thermo switches with 1 low temp & 1 high temp. I've bad experience using only 1 thermo switches. In winter, I couldn't get hot air inside the cockpit under normal driving. It only gets hot when I rev up the engine to high RPM.
