Erractic Behavior......Help!!!!!
shatcher80
Hello! So I own a 1991 Lexus LS400 V8 and I just had the starter replaced. I drove it home and noticed some strange things happenning.
1. The oil light,battery light, brake light,temperature light, and trac light were all on.
2. The dash lights were on but when I press the brake they go completely off except for the P,R,D, etc...
3. The idle on the car is extremely low.....about 150 to 200 rpms.
4. Battery went dead after attempting to recrank.
Now I had the battery tested and it was good. Once I installed it all the lights in problem #1 went off except for the trac. Now I just have #2 and #3 to worry about. Not sure where to start because there is no CEL and no codes. Any suggestions?
Before u had starter replaced did it have these problems
Sounds like they might have shorted the thich battery pos cable on the starter
To ground which might have blown the alternator fuse
Or maybe there's an air leak
Check ecu for faulty capacitors
