newmon1978
- Messages
- 17
- Location
- namibia
pins 2 and 3 on air flow meter. yellow black pin 2 yellow green pin 3. take a normal 12v test light the 1 with a bulb that lights up not a digital 1. connect the clamp to ground and while the engine is idling stab the other end into yellow black and then yellow green.listen to the cars idle listen for change.If it should rise it means that your airflow is faulty.but then also check pin 1 it should be ground and also pin 5 it must also be ground that colors shall be brown
