dannyboy77
Hi all have a bit of a problem with the A341E autobox. I have recently put the 1UZFE and autobox in the surf and have the lexus combination meter in and using the surf speed sensor 1 (& lexus magnetic 4 point speed sensor 2 to run the lexus ECU) to work the speedometer however I found out the pulses given out from lexus speed senor 1 to the lexus combination meter is 20 and the surf only give 4 per revolution so I am getting a 1/5 of the speed reading on the head up display, that’s not the question just a bit of background.
The problem is after the car has been travelling for 20mins of so, so up to operating temp the autobox decides to change up gear from O/D or 3rd to say 1st 2nd for a bit then decide to find a gear it could be OK after that or play up for a bit then settle, if I take the O/D off it does seem to be OK
Any ideas I have been running the car for a few months now and only has started to do this in the last few weeks.
