5.7L Swap
Anyone doing this swap into any Lexus cars? TRD make an intercooler supercharger that will put out 504 hp and 550 lb tq:
Unique design fully integrated into the engine with the latest generation Eaton® Twin Vortices System (TVS) roots-type rotor pack. ---The twin four-lobe rotors feature 160-degree twist improves air-handling, noise, and vibration characteristics - Kit includes: -- High flow fuel injectors, single belt drive, and lower heat range iridium-tip spark plugs. -- Water-to-air intercooler system with a custom low temperature radiator (LTR) -- A new performance air Intake system is included in the kit with a TRD re-useable performance filter, Intake Flow Accelerator and a larger upper air box lid with a filter service gauge. -- 50-State emissions legal. Power: 504hp up from 381hp / torque 550lb-ft up from 401lb-ft. ALL POWER NUMBERS CERTIFIED TO SAE J1349
Installation time is approximately 9 hours
As we speak, we are using a digital tracing of a engine guard. This will definately going to support big HP. Making more then that would need new rods, pistons, engine guards and head studs along with tri metal bearings.
very awesome, I was going to buy an engine off ebay but someone beat my bid by 20 bux about a month ago. I'm still looking for one, and have someone ready to make an adapter plate for the getrag transmission as well!
Lex I just bought my next supra and I've been thinking of trying this swap. First off will it FIT is the question, the heads are nearly an inch from hitting the strut towers on both sides. But the main concern is the oil pan, sure its mounted at the back of the motor but the oil pan is long and narrow. also the new style oil filters on these motors hangs down like a huge hornets nest and might interfer with the steering rack.
its also hard to find someone that would make a clutch/flywheel combo for the viper transmission to mate to the 3urfe....
I'm personally going with a 3uzfe w/ v160 as its different yet still has parts made up and proven to work.
