1UZFE speedo wiring info needed?
mazdadrifter
Pretoria, South Africa
Good day all.
I did an engine swap on my GWM 2.2i double cab with a 1uzfe, autobox and original ecu.
I bought the setup and installed it.
Got all the other wiring like oil light, rev counter and reverse light sorted.
My problem is wrt the speedo.
My pick-up has an electronic speedo (cluster) with a +, -, G (12V reading with ignition on) and a Vdo (12V with ignition on).
Do I use the speed sensor right at the back of the autobox with the 2 wires to do a parralel connection to my speedo's Vdo?
If so, which wire(s) do I connect en where?
Regards
Pieter
