1UZ into E36
Even on hot days, it cycles between 90 and 87 degrees C with the fan.
The radiator is excellent and keeps it in the mid to low 80s when driving around.
Not entirely happy with the filler though... no matter how I bleed it, the system seems to keep a tiny pocket of air in the upper hose - but I have another bridge pipe to weld up and that should fix it.
While there is much more to do on the car before it's finished, I am nearing the point where it's ready for dyno tuning. One of the main concerns I had was the cooling system. The current setup is:
  • Chasebays Radiator with dual pass core
    22" x 17" x 3” (W/H/D)
  • 20AN fittings with 1.25” hoses
  • 16” 2200 CFM Thermofan
The system (including engine & heater) holds about 8 litres of coolant and the fan moves a serious amount of air. This is one area I didn't want to skimp on.
Due to the Chasebays radiator being lower than the top water outlet, I had the thermostat housing modified, with a filler welded on where the bleed plug used to be. This was OK, but the top hose always seemed to hold air, no matter how I purged the system.
Temp-wise, the engine would normally cycle between 91 and 87 degrees with the cooling fan - but after some “enthusiastic” test driving on hot days, the temp would increase 95-100 for a few minutes before coming down. On switch off, there was always a gurgling sound. I needed to get the air out of the top hose, and I wasn't 100% confident it would stay cool during punishment on the dyno.
The Chasebays radiator also came with a filler neck that I hadn’t used (it was still too low), but it's now come in handy. I had a spare front waterbridge (early LS400) and the outlet has now been cut off, with the filler welded on. A standard thermostat housing has been re-fitted (would look a bit silly with 2x radiator caps).
The LS waterbridge has 2x additional fittings that the Soarer doesn’t. Now, 2 are welded up, with the temp sensor in place and the remaining 16mm fitting makes good as an inlet from the turbo.
With the new parts fitted and the system bled, N.O.T temps are stable no more gurgling. It takes a fair bit more punishment for the temps to get past 95 (its about 30 degrees in Sydney today) but it cools down just fine. I'm confident it will take the heat now... but the dyno will be the ultimate test.
Nice neat job there Patrick.
I have similar heating issues when I work the thing a bit. Now running a low temp thermostat, a push fan PWM to start at 88 and the twin pull fans at 90 seems to work at the moment.
The biggest issue with a blower is high IAT's, sometimes mine is up over 80C however the water meth brings it down under 50 pertty quickly.
Does your 2 wire IAC make much noise?
I've been tossing around the idea of using a 2 wire in place a my 4 wire stepper to recover some outputs.
Keen to hear your dyno results
The 2 wire IAC Solenoid does buzz a little when the engine isn't running but its imperceivable as soon as the engine starts. The closed loop on it works very well.
I did some data logging today and the air temps sit around 30-35 degrees when running 6psi - but the sensor seems to heat soak a bit when the car is idling. Comes down quick enough. I'm sure it will get hotter on higher boost but that's an issue to measure and deal with when it's on the dyno. I need to adjust the exhaust position a little and get the thumbs up from the engineer on the intake before we hit the dyno.
Just a word on that... the engineer says:
  • Engine capacity and induction are the same as a BA XR6 Turbo
  • Brakes are on par (slightly bigger) than a BA XR6 Turbo
  • Therefore, I must not make any more power than a BA XR6 Turbo
So, the target for engineering is (only) 220kw.
After some more testing, the engine was faster to heat up (past 95c) and taking longer to cool down.
In theory, the coolant velocity through the front bypass pipe would pull fluid from the turbo back into the radiator.
Turns out that Setup 1 (below) causes the outlet flow out of the engine to slow down, and the front bypass pipe (which houses the coolant temp sensor) was getting hotter than normal. This would explain the measured temp getting hotter faster and staying hotter longer.
I had a look at the turbo coolant line setup in comparison to a 2JZ-GTE and found that I should have plumbed the line into the water inlet housing which is above/behind the thermostat - just as Toyota had designed the 2J to do. When connected in Setup 2 (below) the water pump now pulls the coolant through with much greater force now and the temps are more stable.
Please don't make this mistake.
So, I'm using genuine ignition coils from a Lexus ISF (part# 90919-02260) - they slot into the tubes nicely but the fastener hole is slightly off the threads in the rocker cover. I wasn't worried about this as the coils clip firmly onto the top of the spark plugs and need to be pulled firmly to be removed.
During inspection, the engineer mentioned this was a potential fire hazard (make of this what you will) if they came off - and insisted that they be bolted down... so I made a bit of a mess in the garage over easter and sorted this out.
Using some 10 x 30mm alloy flat bar, I made 8 of these (the countersink depth I couldn't tell you, but the screw sits flush with the top).
The chamfer on the bottom is required due to the weird shape of the rocker cover around most of the spark plug tubes
With the little mounts attached and aligned, I marked out the bolt hole for the coils then drilled and tapped them for M6.
The cylinder 1 & 2 coil mounts are both different to each other, and the rest of the cylinders, so they needed some additional work.
Sorry, no dimensions on the additional pieces - but if you have the tools and are smart enough to make the other mounts, you'll be able to work these out for yourself.
  • Like
Reactions: JZH
The rest of the engine bay got a tidy up with, some hoses were trimmed to the "correct" length, and I made a hard pipe to run coolant from the turbo to the top of the thermostat housing.
The last few weeks have been momentus for the car - engineering certification, AUVIS inspection, and finally registration this morning. The car is 100% legal and we've just taken it for a cruise through the Royal National Park in Sydney. What an amazing feeling to have 5 years of hard work come to fruition.
The engine is smooth and lazy when cruising and the fuel economy actually isn't too bad. Lean on the gas though and it absolutely storms.
In engineering config (super quiet and restrictive exhaust and only 5psi) the car makes 285hp at the wheels, but on 12psi, it's making 400. This is also with 16psi of backpressure in the exhaust after the turbo.
With a proper exhaust, I expect it will make 450+ on 14psi. For now though, I'm all about enjoying the car and sharing it with family and friends who have been part of the journey.
Some reflections on the build after a month and a bit of driving:
  • It breaks axles. The standard outer BMW CV joints were never designed to take this amount of power and I'm onto my second set now. Billet stubs with Porsche CVs are the bulletproof option for more than $5k, whereas cheap replacement CVs are $200. and I'm back on the road.
  • This is the reality of doing an engine conversion + turbo. Unless you build everything bulletproof in the beginning, you will continually break and repair things until you make it fit for purpose. I'm under no illusions that the gearbox and engine will last forever. The diff is already sounding a bit tired.
  • Cruising is effortless and fuel consumption is surprisingly good. While it was never built for economy, it will return around 10L/100km when driven gently. Watching the fuel consumption values on boost though is laughable.
  • The 'sleeper effect' is a strange thing. It's not lowered, or stickered up - it still has the 320i badge on the back and a stock sounding/looking exhaust, so most performance car drivers don't even give it a second glance and neither do the cops (which is good).
  • The only recognition I seem to get is from other people driving shitty old BMWs in traffic. I'd compare it to having a broken leg in plaster, then walking past someone else with the same injury. It's a look of commiseration and empathy.
  • Most of the runs I've had are with hot hatch guys who will race anyone, and don't suspect a thing - the look on their faces is priceless... but it's a hollow victory. Tortoise vs hare.
  • More power is almost pointless. In a world of alleged "street legal" and "daily driven" cars that make +1000hp, there comes a point where it is completely unusable. At 400hp, I feel like I'm reaching that point. On 245's, 1st and 2nd are a waste of time and 3rd feels sketchy. Another 50hp, once the exhaust is done and retuned, is going to be more than enough. Going wider than 255 tyres requires cutting and flaring the arches. No thanks.
  • Driving in the wet requires swift hands or a significant amount of self-control.
I hope to take it out to Sydney Dragway over the coming weeks to see exactly how fast it is.
PB
UPDATE: I decided to rebuild the diff with a Nismo GT LSD and 4.4 gears (up from 3.7) but was faced with a 2 month wait for new Stub Axles... so I picked up a cheap S15 diff. It uses a torsen centre and is amazing to drive. Hooks up when it needs to and has good manners in tight turns and carparks.
The Nismo diff is finished but I'm hesitant to install it - they are known to be excellent on the track but can be cranky for day to day duties. Think I'll leave the torsen in for now.
Finally started work on the exhaust and just finished the 3.5" front pipe today. Boost response is almost instant now and it comes on extremely hard. Sounds nasty without the rear pipe but that will come later. 2/3 the weight of the original pipe. Antilag sounds like thunder.
