EIL_V8
- 23
Hello again.
I had a look at wiring and all seems good outside of intake valley.
Question:
When jumping starter relay terminals in fuse box, does this bypass all other systems such as neutral start switch and ignition?
For example, the USA cars have immobilizers.
If immobilizer is active for whatever reason, will jumping the relay terminal in fuse box for starter motor cause the starter to try start car, or can something stop the jump from working?
When I try jump the starter terminal in fuse box, there is no noise at starter motor. Relays click (2 or 3 times I think) when key is turned to "on", but nothing happens when trying to crank and dash shorts out til key is released.
Auto elec claims open wire underneath manifold, or wire to starter is off, or starter is faulty... But he only checked the starter relay terminal thing in fuse box, no ignition or shift test, etc.
Thanks guys!
Question:
Thanks guys!
