redrocco
- 160
- Rochester NY
I have spent days reading and searching the info on cams, valve springs retainers, shim over/under bucket, shimless buckets and now I am even more confused then I was before. I am planning on ordering a set of Kelford 207-S1 supercharged cams. Kelford says that these cams should work with the stock valve train but I would like to play it safe. I plan on running about 12 to 14 PSI of boost and my redline is set at 8000 RPM. I don't need to go ballz to the wall crazy but some springs and retainers that are going to do the job but not break the bank would probably be a good idea. I have looked at the cribbj posted and could not figure out what to use. Would the stock retainers work with the Ferrea S10110 springs? Will the stock retainers hold up? Trying to stay within a budget of $300 to $500 for springs and retainers. What do you all think?
