3uzfe vvti swap difficulty
davnaris
Arima, Trinidad and Tobago
I want to swap a 3uzfe vvti engine into a 1987 volvo 740 stationwagon but the vendoe of the engine does not have the ECT ( Drive by wire) pedal assembly that is for that particular 4.3 lexus engine. How can I get this engine to work without the ect pedal (drive by wire) ? and can the transponder key wiring be bypassed ? need all the help that I can get on this.
gloverman
Well-Known Member
Hamilton. New Zealand
I've done some 3uz on 1uz management. They go OK but there are a few holes in the map where they go flat. Even when doing aftermarket when I swap between tunes they perform very differently. They are definately much easier to wire though.
hiluxfan
Muscat
If you already have all the wiring harness, ECU, immobilizer etc. just get the Lexus pedal and make it fit.
It isn’t easy to bypass the immobilizer and key but can be done. Speak to Gloverman.
