1ZUFE into Mitsubishi Delica
Lleksam
Shropshire UK
Hi ALL
First Thank you all the moderators that worked so hard getting my account verified, something went wrong while registering.
Im a semi retired Maintenance Engineer, my plan is to transfer a 1ZU into my 2wd Mitsubishi Delica
I have bought a road worthy 1994 LS400 100 miles from home and drove it back it ran real well, will be stripping engine and gearbox out in next month or so, I have also bought a SupraStick SS-V4 was on ebay at right time at right price, will do transfer make sure all is working well then look into a Eaton M112 for top,
If any one wants any bits off Lexus that i wont be using there here for collection and a pint
Thanks for reading
Steve
cribbj
"Supra" Moderator
Houston, TX
Steve, first of all, welcome to Lextreme and thanks for your perseverance. This has been quite a marathon for Rod & me, as well as David himself, getting Steve's membership activated.
We still don't know what happened, as others have joined the website well after Steve, and received their activation emails, and have posted!
Nevertheless Steve, you're here now, and we appreciate your interest and look forward to following your project.
Lleksam
Shropshire UK
I have removed engine and gearbox wiring loom and is all boxed up ready to send to Bushwhacker for him to work his magic on it, so I get back a almost plug and play loom, that I can modify to take the SupraShift auto/manual gearbox piggyback ECU and the Prins LPG injection setup with its ECU
Steve
Lleksam
Shropshire UK
just a quick update
bits back from painting, so could not resist a mock up, water pump, cam belt kit and head gasket set on order
wiring loom still away, but sure will be back soon
here is what it looks like, in Pontiac light blue metalic, its a lot lighter colour than i expected
Lleksam
Shropshire UK
Bit more of a update, all rebuilt, and back together with new water pump cam belt kit etc, Strange they dont include the gaskets for the water x pipes in a Gasket set??? when wiring loom gets back from bushwhacker will install that and think about fitting in Delica.
Zuffen
Super Moderator
Sydney, Australia
A question if I may,=?
Did the Lexus come fitted with the oil cooler at the oil filter?
These are usually only on the Landcruiser version (2UZ)
Certainly looks nice.
Lleksam
Shropshire UK
been a good day for deliveries today, LOOM came back all modified ready to plug and play will fiddle tomorrow, Thanks BUSHWHACKER great job, the EGR blank lazer cut plates were ready too for collection from cutters, all nice in 5mm Stainless Steel, I found in Maplins some 20 pin male and female molex plugs for the LPG injectors I found a home for UNDER the inlet manifold out of sight the nozzles will go in under too, so there will be little of the LPG seen
Lleksam
Shropshire UK
loom in place on engine, need to repair or replace lpg loom at moment just put 20 pin molex on LPG injectors because i cant get to plug in with inlet in place, but theres a awfull lot of wires even without lpg one, Bushwhacker made the LPG and Suprastic easier by identifying wires for me when he did the conversion to engine loom
