1UZFE Powered Airplane
Vate
Hastings, New Zealand
I purposely over-designed the Belt drive PSRU and it can handle 1000hp. There's nothing like having heaps of redundancy in an aircraft...
I;ve been running the motor at normally 3200 rpm in the cruise, but that was only because it was the smoothest rev for my nerves due to a slight vibration. I recently spent a whole day using a friends new dynamic balancer to balance the prop to perfection, and now I can run it at any rev and it doesn't worry me.
It's now just a noise machine...no vibration!
No mods apart from those needed to fit the PSRU - and a back up Ignition and fuel system. Generally, the more you can keep an engine stock standard in an aircraft, the more reliable.
Vate
This is a couple of videos taken out of my latest aeroplane designed specifically as a Glider Towplane - once again with a 1UZFE, but this time using an Autoflight gearbox (to reduce the speed of the propellor) made in Hamilton, New Zealand.
It was initially flown with a factory standard ECU, but it kept shutting the motor down at various heights so I replaced it with a Megasquirt.
https://www.youtube.com/watch?v=4683CRX6EOo
https://www.youtube.com/watch?v=tWad1n4efoI#t=263.721
BigKriss
South Africa
hi kriss,
sorry for the late reply,but just came back from the usa!!!
the aircraft is at springs airfeild!!
let me know if you want to see her and go for a flight?
regards
micsa
eaa oshkosh was awesome!!!
2007 !! Hope you are still flying and enjoying your aircraft....!
