Hi everyone,
I have an enquiry that I hope you can help me with. Basically, do I need an AFPR or will the stock one be more than sufficient?
I have an early 1UZ-FE and I am in the middle of fitting a Ford M112, along with 300cc injectors (up from 250cc), a water/methanol system and a Walbro GSS340 fuel pump. I will be running the M112 at approximately 9 PSI boost.
As this is all going in a MKIV Supra, I still have the stock NA Supra fuel control ECU in place, it's working fine, and I will be running my stock Soarer ECU too.
At the moment, the stock FPR is still on the fuel rail and I have an AEM AFPR fitted in the engine bay, but not connected to anything just yet.
I'm not chasing big power, I just don't want to run lean or far too rich.
Any advice would be greatly appreciated.
Thanks!
Thanks!
