Thanks for input guys!  4U2QUIK, are you doing injection molding or cast?  We have a product line at my work that I am the only engineer responsible for so I have been talking a lot to the plastics place we use to inject a urethane seal on our valve, and you can see some of the shrinkage, but I understand this to be a bigger problem with injection molding and not casting.
Okay, so today my new vacuum bell jar came in!  The glass was not quite as smooth on the surfaces as I hoped, making it hard to see through a little bit.  Anyway, went down to autozone and rented an A/C vacuum pump and used that to power my chamber.  It worked GREAT!  Now this was a rinky dink rental model and it still performed very well.  I put it in the chamber and turned on the pump and bubbles slowly started to rise, but the whole liquid seemed to expand, all the way to the brim of the cup! (Cup about 5" tall half filled)  All the bubbles started to pop and the resin started to fall so I kept the pump on a bit after it fell too.  Turned off the pump, slowly released air pressure back into the chamber, and  marveled at the process and how jet black and clear the resin was.  As I was releasing the air back in, you could see the resin becoming more and more smooth on the surface.  After that I slowly poured it into my mold.  After I poured it I put the mold back into the chamber for a few extra minutes and pulled it back out.  Wow is all I have to say, it came out so much better this time.  I shot a video of it, but next time a will shoot a few stills to upload here so you can see what it looks like.
When I was doing my research I read that after you pull a vacuum on it you can actually pressurize it in a chamber to further decrease bubble size and let it cure in the chamber.  I don't think I will go that far, but its a great idea.
