92LS400 Dainty Little Dither
Amskeptic
I love this car.
124,595 miles on it this morning, everything works beautifully but . . . .
a whisper of a delay in torque-converter lock-up. Every single application of accelerator comes with an almost imperceptible "slip" of engine rpm ^ before it goes back down and pulls the car forward.
What tells the torque converter to lock up after it has released during coast-down. TPS? Cable that must be adjusted on throttle assembly?
Colin
The ECU locks up the converter. It calculates lockup based on speed and tps movement mainly. Im running a 91 ECU and it locks up in third and fourth at 60km/h and drops out at 40km/h on decel. Hard acceleration results in lock up dropping out but light acceleration it stays in.
Are you sure its lockup dropping out and not a clutch slip? Whats the oil quality like?
Oil quality is a sweet translucent red.
I know there is not a shift of any sort every time you hit the gas, but does the torque converter lock-up use a clutch pack?
I am getting this weird slight engine-up-back-down hesitation in lower gears too. Now I am confused.
Colin
Converter lockup is solenoid controled which monitors to oil flow to the converter.
I hocked up my oscilloscope to check the command as a start.
IS your engine running as it should? any chance it is due for some maintainence?
