Sorry to hear of your accident. :o At least you're ok to go on the forum. :p
I thought your turbo pipes were designed and fit perfectly. However, I understand this type of project usually has some surprises in engineering. That's the spirit of it, but don't give up. lol.
Steve, they were. But they were designed for the other twin fan set up and that proved insufficient to cool my car and maintain proper engine temps...so, once I came up with the new fan/shroud set up, the overheating issues have been resolved. But now the piping is a bit tight for them, although it dies fit.
I have decided to dyno tune the car first, then decide if I need to go with the new tubing. 1,000 WHP is still my goal. So I need to get a baseline and determine then whether I need more fuel, bigger exhausts, more aggressive cams, or a combo of the aforementioned.
I just got the car back from the Orlando Lexus Dealer, and I must say that they did a great job...the previous painters disassembled the doors to properly paint them, but then they reassembled them incorrectly by not using the factory screws and instead using sheet metal screws that screwed into the rear door trcks and interfered with the windows rolling down...the driver side would lower 50%, and the passenger would not roll down at all!!! Unbelievable! And since the economy killed that shop, I could not go back to them to fix it...so, I had Lexus do it, and they did it right. I had them fix the door lock clip and align the car too. Drives like a dream...:)
I took it out for a spin this afternoon down Markham Woods road...a winding road that has lots of high end sports cars driving on it...I drove up behind an Audi R8 Spyder...gorgeous car, and one I plan on buying within the next few years ( non-Spyder). When he first saw me come up behind him, I could tell he wanted some, but then he heard my V8 rumble along with the Turbos...he backed off...when we came to the intersection, he was turning left into Alaqua Lakes, I was going straight...So I gave him a little taste...took off quickly, but only a chirp (didn't push to hard), but shifting into second while on manual mode at that rpm broke both rear tires loose and left some serious sound and black streaks...I was grinning from ear to ear...:D
I can't wait for the dyno tune...
Ryan
Nice to hear you take it back. Although the 1UZ engine barely moves, but it's good to have some clearances between pipes and other stuffs.
An R8 against you? He won't have a chance. Lol.
The Dyno went ok...Meaning, Darin did well, but my wastegates did not cooperate well. The Actuators had to be moved and custom mounted when the plumbing was fabricated and everything fitted so they did not function properly, and the result was we could not control boost, so the ECU kept on boost cutting before my car could even get to 5000 rpm's and Darin was never able to get a good run. We called it a day after about an hour and a half of working on it. Managed to see 439 WHP at somewhat less than 4900 rpm...I believe that was at around 4600 rpm...Darin said not to even pay attention to that number as it was a lousy run. So, I have to replace the actuators and hook back up with Darin in the next week or too. We will get there...I have posted up 2 videos from the day...It was not a total loss as Darin got the idle very stable, and he tuned in exceptional driveability...The car is absolutely fun to drive, it is very quick, easily breaks the tires loose at partial throttle when using E-Shift in 1st, 2nd and 3rd. I can't wait for the next tuning session.BTW, the built V8 sounds absolutely awesome!!
Ryan
Video 1:
Video 2:
Ryan, congrats for finally getting it to the point of beginning the dyno tuning.
While disappointing to not be able to control the boost you are at least getting an idea of what it will be capable of.
439whp is somewhere over 500hp engine hp. 500hp @ 4600rpm = 571lb/tq
Thanks John. Amazing how much the car "woke up"...Now to enjoy the car and take it to the next level...;) Driving it is just totally fun!
Ryan
Bullseye Power called me back first thing this morning, and told me what I need to do to adjust the issue. There is nothing wrong with the actuators...But they are large wastegates and even though integrated types, they simply need to be adjusted. None of us knew how to adjust them though, and Bullseye just called me and told me what to do...Should be an even easier fix, and quick. So, I will be back on the dyno real soon.
Ryan
