It has a very high idle, and it increases as it warms up. To me, that's acting like an unmetered air leak, so it should be running lean, not rich.
I know you said it's pumping black smoke out the exhaust, but what do the plugs look like?
If you want to test for air leaks, get a squeeze pump spray bottle and fill it with water, and start spraying around where the intake manifold bolts together, and then where it bolts down to the heads, and also where the throttle body bolts onto the manifold. If the RPM's drop when you spray water somewhere, you've found an air leak.
Some people do this with engine starting fluid (ether), which makes the RPM's increase, but it's also a good way to get your eyebrows singed off......
