LSD Diff options on a LS400
Fasteddie
Guys,
we are rebuilding the diff on a '96 LS400 (UCF 20)...this is not the same as a '91 LS400 diff.
The Torsen diff doesn't fit in the "clock"....
We are thinking of changing the subframe to a 97 LS400 (vvti), which equals the Supra subframe...
Anybody knows which other lsd-diff does fit into the '96 LS400 so don't have the complete sub-frame ????
We want both wheels spinning...no mig diff :madfawk:
THX !
i very inyterested to know what torsen diff to be exactly would bolt strait into a 1990 LS400.... being trying to find this info for ages
Has anyone read the whipple LS400 Hypronet is making?? He has an LS like ours w/ supra diff swapped. i asked a bunch of questions and it works! Its got some steps 9as expected) that make it a little morethana bolt on job but do-able nonetheless. I guess the supra turbo diff has 4 blt locations and a 4th on the early LS needs to be added. this means you will need to drill a 4th hole in the subframe and weld a matching nut to the metal to bolt the 4th location to. Once the whole unit is swapped the driveshaft needs to be modded. The Yolk needs to be adapted for the supra diff but thats it. i dont really want the high gears (4:10 I believe) so i might get slightly higher than stock (3:88 or so).
That seems like a bit of money! Does anyone know if cressidas are a g series diff, and they also have irs. If so that would make them compatible to the ls400 diff and that would mean the m70supra lsd would fit?
Guys Pm Lextreme as he should know the answer to this question.... The Supra torsens fit perfectly onto the SC400's as I am driving with one right now... Not sure about the LS400's..
thanks jibby haha we know Sc's straght swap... the LS has been a debate for some time now and I have not seen a single documented conversion except for Hypronet's.
ok anyone who knows the inside of an ls400 diff real well? 1st and 2nd pics are a g series ma70 supra lsd do they look like they would fit.
The 3rd pic is a cressida grande lsd which is also a g series which nearly looks like a bolt up proposition. Can anyone verify this
so the cressida on the far right will take a g-series LSD? If so then i think your close. I like how it has the 3-mount config. over the 4... makes install cake. Only answer to our problem I could find was a 97 LS swap but it require some fabbing for the 4th bolt hole. Def not straight swap.
I suspect a custom drive shaft with whatever choice is made so i wouldn't bother looking at the yolk. I would try and measure the 3 mounting locations and look for similarities with LS. the supra diff and 97 LS have 4 holes and it just looks apples from oranges but doable. I'm not a Supra expert but what year did the ma70 come in? and turbo or non turbo?
In the far right pic i can't see the lower mounting arms, maybe they bolt on the sides? The top mount thats visible in the pic looks like a close match but I can't see the larger lower arms that should e in there.
Cressida Diff
.. Yes, the '89 onwards cressida diff is a 'G' series and the cressida Grande had a G315 LSD...
cressida diff
yes... i had a 1990 cressida grande which had a LSD 'G315' and it worked fabulously well... it had 400,000km on it when it went to cressida heaven (2nd engine died of terminal head gasket issues) but the diff was still working fine, no noises.....
er no... no LS400 came with a factory LSD.. seems like lexus is very anti LSD... even the 400hp IS-F didnt come with an LSD until 2010
Thats crazy... 420hp and Lexus left it as a 1-wheel wonder
Is-f lsd
Yeah..... W.T.F. is it about Lexus and there anti-LSD B.S. ? my 1998 LS400 has 290hp and open diff....GRRRRRRRRR... even my 200hp cressida grande had an LSD...... poofter !
Torsen unit...
G'day mr hypronet... i have a 1998 LS400 and i'm getting closer to installing a Torsen center.
Q1: Do you know if a Torsen 1 is the same fitment as a Torsen 2 ?
Q2: Do you know what 'way' Supra Torsens are.. i mean 1, 1.5 or 2 way ?
Q3: Can i assume that the UCF21 diff is an 8:3/4" ?
Q4: Are all Torsen 2's the same size regardless of age ?
I believe the UCF10 and UCF20 diff centers are different.
Q5: Could i then assume that a 1998 and onwards Supra Torsen would fit a 1998 LS400 ?
Q6: What year did the Torsen 2's come out ?
I hope someone can assist me with these questions.... (i can't wait to
start some serious hoodlum drifting in the big UCF21..... especially in the rain!!!!!! ) Yihhhhhhhhhhaaaaaaaaarrrrrrrrr !!!! :)
