ok then..not done supercharger setup before (diesel man me, up till finding this bloody site and hense fitting 1uz into range rover...so much cash...now i need a supercharger...)done plenty turbo setups,but all been on diesels..
so..got new m112 (for jag fitment,long nose)fitting to 1995 engine,8psi max.
where to fit?2 options..
1) standalone,above 1,3,5 and7 pots to one side,running plumbing to intercooler (air to air) and then to manifold....mafm,tb,prior to supercharger..disadvantage looks poo..
2) mounted on to inlet, inlet machined down,ali plate welded to manifold,supercharger mounted to that..downside,sticks out bonnet,no intercooler..will i be able to do this?(have not got supercharger yet, in post)..ie is there enough room on manifold?
next..engine breathing,what extra will i need to do apart from running rocker cover breather pipes to inlet of supercharger..
next..where/how does the idle control valve go, surely won't work where it is unless it gets its air feed from boosted side..(just answered my own question there i think..hmm need to think about that..)
next..its ok to mount tb,mafm before supercharger,so never sees boost..that seems the place to fit them..(or can they be feed forced air if needed..(if for instance mounting supercharger not on the manifold)
next..will i need larger injectors? (remember only 8psi max)if so size and what vehicle they from please..
next..ramping up fuel pressure..will the standard fitment one work, or it not work on boost just vac..?
next...want to keep standard ecu for the timebeing..(cost and keeping downtime low..ie need to fit in anight (at work in warm workshop) once got everything ready to go)
next ..boost..how to keep to 8psi,but to get boost asap,lower the revs the better, as after more low down torques rather than max top end power?is it just via the gearing, i assume blowoff valve essential (just in case)
next..where to buy pulleys.ones you reccomend??rather modify and make..
anything else i have forgotten/tips please do tell..
sorry so long,but am sure a few helpful pointers will save me hours of "bugger thats why you dont do it that way" times..thanks
