Rod, you must have been sick when the grit flew in to the motor. This build and rebuild has really been an exercise in perseverance, hasn't it?
At least you stayed with the shim over bucket setup, so when the shims got mixed up, it wasn't a total disaster, as it would have been with a shim under setup.
Did you install extra drive pins for your cams? Would really like to see those if you have pics?
