scotturnot
- 954
- central US
I Used to own it, Sold it to Zach, he never even plugged it in so its back up for grabs!
Here is the scoop on it.
100% Plug and play!
its a brand new turn key Adaptronics stand alone ECU. I originally purchased this stand alone ECU and then I bought a supra jumper lead. I posted the jumper harness to Neil Griffiths in Australia. Next I paid him to wire it up as a turn key plug and play unit. Neil is running this exact stand alone on two different 1UZ cars running 15lbs boost with great success. He wired it up and ran it on his car for me to verify it was plug and play. Even had it dyno tuned at 10lbs boost and 15lbs. It comes with both Maps! It is going to practically run right out of the box.
If you plan on boosting a SC400 this is a great chance to get into a plug and play stand alone at a great price. Not to mention you wont have to wait months to get a unit made up and shipped.
This is the closest thing to a run out of the box setup you will ever find. You will need to upgrade to larger injectors (it was tuned on 390cc) and add boost. It will include both a 10lb and a 15lb map.
When I bought this the cost for the ECU/wiring labor and test/tune was About $1400 as I recall, then I bought the TT jumper harness for another $390, paid about $40 shipping to Australia so in total i spent almost $1900 dollars having this thing set up. It is literally brand new.
I will let it go for $1300
100% Plug and play!
