Hi all,
Has anyone taken the oil filter housing off a soarer engine? I'm fitting the 1uzfe into a Lotus chassis, and there is very little clearance from the steering rack.
If anyone has an exploded diagram of the housing as it fits onto the block I'd be grateful to see it.
Or a quick summary of how to remove the oil filter housing from the block?
What I'm hoping is that I'll be able to mill down the housing to bring the oil filter housing closer to the block. ie vertically higher and closer to the crank centre line. The vertical level is the bigger issue.
Is there a remote oil filter option?
Last resort, does anyone know the thickness of the pipe that comes down out of the housing then goes into the filter, if a few mm could be ground off the bottom at the 90 degree bend, that woul probably suffice.
Any responses or suggestions appreciated, sorry if this is in the wrong place.
Cheers, Mat Grant.
Cheers, Mat Grant.
