We are proud to introduce the new Megan Racing high performance aluminum
radiator. Anytime an individual introduces their car to a racing/drifting
environment, the temperature of the vehicles engine will skyrocket. One common
and effective method of reducing engine temperature is to employ an aluminum
radiator.
This is a cost effective upgrade which can ultimately save an engine during
competition or spirited driving. Often times, a temperature drop of twenty
degrees or more will be noticed when using an aluminum radiator. Also included
is a 1.1 BAR radiator cap. Cap itself is like $40 already. Some
other radiator doesn't come with cap but this one does.
This radiator is amazing. If you really keep good care of it, it should
outlast your car. Keep it the fluid clean by changing it once a year.
Here is the same radiator in my Twin Turbo SC470:
BEFORE:
AFTER:
ATTN: Please FLUSH the radiator before installation and properly take all the
air pockets out. If its not properly installed, might cause the motor to over
heat due to low coolant or air pockets in the cooling system. Just for
$265 plus shipping. It is literally cheaper then radiator from Lexus
dealer. NOTE: Some Mods are required!
