stevechumo
- Messages
- 3,054
- Location
- OC, City of Sunshine
Folks,
I'm thinking of a twin turbo system with a large T70 and a small T25. The purpose of the system is to eliminate tubo lag if using only a single T70. The power goal will be the same as with only a single T70. By adding a small T25, the T25 will spool quicker and will flow the air quicker to the engine, which eliminates turbo lag, while the T70 is still building up boost. In this case, the t70 will build up boost slower than if it's in the system by itself. So once the exhaust pressure reached a certain point, the T70 will fully kick in and take over the T25. My thought is: will the T25 will be damaged, or will there be any other problems?
This turbo system is more simpler than a sequential system, but will it work?
I don't draw very good with the Microsoft Paint, but you can get my idea.
