mxcowboy1
- Messages
- 8
- Location
- Grafton NSW Australia
Hey Guys Ive recently got hold of a I believe a 1991 Lexus Soarer sc400 UZZ31
GT Limited
It has a couple of issues
Firstly the error codes
ETC 63 which is no2 shift solenoid? This would seem correct because it often shifts straight from 1st to 3rd
Where can I get a solenoid from?
And whats a good service manual to get a hold of?
Then theres error code EFI 13 which is RPM circuit no2 or cam sensor??
Been told this could be a timing belt problem so I took the covers off to line up the marks and my belts marks have rubbed off but from pics iv found on the net of the marks lined up im fairly confident the left cam wheel has jumped 1 tooth as the mark on the tooth that should line up with the timing mark isnt even touching the belt but would if i rotated it one tooth clockwise is there a way to let tension off the belt to turn the cam wheel back without pulling the balancer off etc etc
GT Limited
