thinking out load..112 manifold
thanks...
here is it so far..only got the metal at 4pm, photos taken at 8pm..not finished as you can see, run out of mig wire..poo:mad:and the brand new hole saw (for inlet ports to manifold) shed its teeth..gonna have a good moan at RS tomorrow...
sc not mounted to top plate yet,not doing that till i know where to mount it!.still to getting bottom and top faced off,can't do that till welded it all up...looks like i dont need a new snout,as i can align it up easy just by moving it along top plate...will need 6 rib pulley though..please see other pulley post.
Looking good.
Why not run the 8 rib to prove it all works and change to the 6 rib if you're happy with it.
6 ribs are known to have slip issues so I would suggest see how it goes first.
I am running 6 rib on my 112, and its marginal. Run the 8 if you can. one problem i am having is belt stretch.
manifold is looking good mate, must be very cheap using steel instead of alloy !
you fitting a chargecooler or just running hot ?
no charger as of yet...where to get 8 rib crank pulley??
im using the intercooler form the new mini, its about 260x150x50, plenty for a first draft :)
also ordered an ac dc tig, it should be here by friday along with the rest of my alloy :)
makinf the inlet from steel though as ive enough lying around
correct me if im wrong but they dont use steel because it reacts to aluminium, therefore vapour in the air will cause the inside to rust if you haven't sealed it(powdercoat or paint) and that will make its way into the engine eventually causing electrolysis. Also i beleive aluminium is a worse thermal conductor than steel so the steel one will get hotter quicker and stay hotter for long
yes aluminium wouod be a better choice to dissipate some heat, but if you dont have the means to weld it, a steel manifold is still better than nothing !
keep up the good work mate :)
ali conducts heat better, ie better thermal conductor..steel stays hot longer.yes it does..so what?they make engines of iron and steel..
ali reacts to steel .yes..i am using gaskets..so they dont touch..takes years to react if done properly..my car is steel and ali panels..they are 40oyrs old and still good..ie it wont hurt nothing...
if i could weld ali i would have done so..but i cant..so...
The internal rust is the worrying part,
Electrolitic corrosion is quite managable.
Assuming it all works well I would recommend having the manifold ceramic coated to try and prevent it rusting.
I know ceramic can lift in manifolds so galvanising may not be as silly as it sounds.
especially if the 1uz's are of the same kind of aluminium as the 4age heads because they were quite succeptable to electrolysis
thanks for all your concern..its staying steel..,.next one will be ali..
it will be getting coated anyway..what in ? not sure..chrome??teflon?
ali is a better conductor of heat..steel is worse.(thats why steel stays hotter longer,it takes longer for the heat to transfer into it,and longer for it to dissapate it...).they use ali for heatsinks cos its so good (and cheap compared to gold and copper )
anyway..coating....galvanising is a possibility too..(and quite cheap)..save hours of polishing compared to chroming..
When you do your next one in alloy mate, if you need the alloy let me know, they guy i get it from (6082 grade) is very cheap, for 4 plates roughly 350x250 12mm thick was about 80 quid delivered for the lot :)
