Speedo not working??
BigEv
Hey peoples, I've been on here a little bit with a 1uz powered 4x4 but have recently picked up a 1991 ls400 to run around in. It needs a little bit of love but nothing too hard. One thing is the speedo isn't working, do they run a cable or a sensor or what? Is there a way I can check and if not is it easy enough to change out?
Thanks in advance
Evan
electric sensor on gbox
check for power and earth and signal coming out of sensor
i know the soarers have issues with dashes sometimes
the lcd screens play up
ive fixed afew but have a read over at soarer central for more info
Common problem and it wont be the sender on the gearbox, if it were the engine would run like shite and log a code for vehicle speed sensor (Whch is part of the speedo). Now the way to tell for sure is when you drive it if the odometer ticks over yet no speedo the problem lies in the instrument cluster. So take the instrument cluter out and carefully take it apart. On the back of the speedo itself you will likely find burnt tracks on its PCB, if you're handy with a soldering iron/electronics you can bridge the burnt tracks with some data/telephone cable if not any electronics repairer should be able to do that for you (Asiat instruments if you want a specialist). As I said this is quite a common problem and at least on Toyota/Lexus reasonably easy to fix.
Oh if the cluster goes dim(Soarer/SC is good for this as mentioned) they have a flouro tube in them, use toyodiy to find it and the part no and then amayama for the replacement part as local dealers not only want your left nut for a replacement but a mortgage over your house too. First born in some cases (I offered the wife on the last one but there were no takers)
if parts of the lcd dash stops its normally the surface mount diodes
ive got a parts tray full fo these diodes for repairing soarer dashes
i had a soarer dash when i was at sss but left it there once i moved up here
if u need another dahs ring em up but i have no idea if it worked ok
came from customesrs car with no idea on history
