Here are some randoms maybe someone can help with. I for sure have one or both knock sensors malfunctioning b/c it throws me the codes when tested. I remember drowning these with antifreeze in the center "V" when replacing head gaskets. Would a symptom of faulty knock sensors result in a loud clack clack clack as my engine accelerates until shifting into higher gears?
FYI: I also have to soon replace my No. 2 Speed sensor in my transmission b/c my overdrive blinks to indicate a correlation with the no.2 speed sensor malfunctioning. Does this indicate a problem simply with the speed sensor or is it a deeper more complicated problem it is indicating?
