ST165ar
- 6
- Little Rock, AR
This is a copy and paste from the Club Lexus forum. Hasn't got much traffic over there. However, this seems to be a more technically inclined forum.
Today my 93 SC400 started acting up on me. I went for a short drive and returned. Went back out a few hours later and would not start. The starter spins fine. During the no start issue, the check engine light does NOT come on with the key in the "ON" position. The fact that the CEL is not illuminated when the key is in the "ON" position gives a good indication that the EFI MAIN relay is a good place to start looking.
I replaced the relay with one from my Land Cruiser. Still no start. Put original EFI MAIN relay back in, still no start. Land Cruiser starts fine with both relays. 2nd try, I turned the key to "ON" (still no CEL), pulled the EFI MAIN relay and put it back in. This time there was some servo sounds, a few relay clicks, CEL illuminated and car started.I was able to replicate the results easily 3 times.
Did a little more reading on how the system works. I think I will start by checking for voltage at the IGSW and MREL terminals during the fail condition. My theory right now is that the ECU has internal issues between the IGSW and MREL terminals. If correct, I will have input voltage at IGSW and no output voltage at MREL. The only questionable issue is: what is happening with the key "on" and the removal and installation of the EFI MAIN relay that causes the system to work?
Ryan
93 SC400
92 Land Cruiser
Ryan
93 SC400
92 Land Cruiser
