Hi guys, I'm hoping for some advice. My 1uz has been in my Monaro for about 2 years without much trouble but the other day while driving the car lurched like it ran out of fuel then started missing, wouldn't rev much past 3grand and had trouble idling. Now I have searched the site and have come to the conclusion that its a stuffed knock sensor. After working out how to wire the engine check light and resetting the ECU it will run OK until it revs over 3000rpm then it seems to go into limp mode retards timing and runs rich. After some bad languish I shut down, check error codes and get 52.
OK heres the thing. Being tight fisted I need to fix it myself. Does someone know if code 52 is the left or right knock sensor or how I will now if I get the rite one.
