I have a 92 celsior 1uzfe in a 84 4runner. I have replaced the caps,rotors, timing belt, plugs.
I was 99% sure i reassembled the belt back on correctly.
I have had the engine smoke tested and it has no air leak as per this machine test.
I have replaced the AFM, drivers coil, fuel press reg.
I am running a carter pre pump with vl turbo pump and surge tank.
factory ecu that the sparky says is 100% correctly wired up.
Symtems... car runs rich on idle and is very ruff, sounds like it has a big cam in it, and stalls sometimes as it idles low and lumpy. exhaust temp is very high at tail pipe. clamp the return fuel hose and revs pick up and seems to idle better but does not fix it the problem. Has plenty of top end and mid range, only surges on idle/cruise.
strangely some cold starts it seems to be running right then seems when warms up turns to rich ruff idle.
Spent half the price of a new engine already trying to diagnose problem!!
have been told AFM, coils, FPR, fuel system, air leak.... yeah all good but hasnt helped me so far. could it be ISC? when u pull a hose off the inlet the engine should rev up but it doesnt. So 1 bloke says air leak, but the smoke test showed nothing.Another says cam tooth off by 1 or 2? but why some morning cold it seems ok and pulls hard/fine up top.
I have had my car off the road since FEB 07 to do this conversion. I spent 6 weeks to get it in, the sparky has fu*$#ed me around for this long with a car now that runs like crap on idle and fear i will now burn out my CAT and my valves. what do i do please help?
