Have had a play today ,while I wait for my resistor I changed the wiring to reflect the resistor being in circuit .motor wouldn't start like it was starving for fuel . The pump would time out which was a good thing but I don't think it was running during start up . I tried it with the pump wired direct and she went fine, so I think the two relays that control the pump are de-energised while in start , so might try again and wire a relay that runs the pump while starting then let the ECU take over once started . It's all good fun , one thing I do like is how the ECU shuts the pump down when the engine isn't running , it just has to learn to run the pump on start I guess . Here's another vid of it running
http://www.youtube.com/watch?v=V8o-zBb1Ol4&feature=youtu.be
