Hi guys it has been a couple years since i have posted but now i need help.
I replaced the engine and put in new cams NA car and it never ran very cool bit of a head gasket leak eventually it got bad and i gave it new ACL head gaskets and skimmed the heads. since then it has useda a lot of water run hot and then when it gets low it really starts to warm up.
i run a big alloy radiator with the hydralic fan.
i have checked with and with out thermostat i have replaced thermostats.
i just pulled the water pump off it looks like new i was hoping to find blades missing cause then i could just get a new one
i have bled and re bled the system in ever manner i can think of.
i have changed coolants to redline expensive additive meant to make things run 10 degrees cooleer.
i have done long diastance highway work to keep the air flow up.
it has no water leaks but in 1 hour it went through 6 litres of water.
i have tested for head gasket leaks and it is clean. system pressure tested fine.
what could it be??? any sujestions.
how do i fix it
how do i fix it
