och
- Messages
- 161
- Location
- Brooklyn, NY
So this topic has been debated to death, but yet again I'm opening another thread.
I'm looking for everyones suggestion on what type of oil to use. I've been using Mobil1 full synthetic in my 01 GS430 and there's not a single leak anywhere, the car now has about 115k on the clock.
However in my 94 LS400 I've been using conventional 5w-30 oil. And in fact it had a pretty bad leak from one of the cam seals and both cam covers. I've recently replaced both cam seals and both cam cover gaskets. Also, I replaced crank seal about two years ago. The car now has about 125k on the clock.
Do you guys think it would be wise to switch to synthetic oil now that I've took care of most these seals? I know there's the rear main seal that can potentially leak, but I haven't seen any leakage around it, so I'm hoping it wont.
Also, what about Mobils clean and high mileage products? Supposedly they have seal conditioners and cleaning agents, but I don't think they are necessary at all in my case since most of my seals are not new. Also as far as cleaning, when I opened my valve covers, the valve train and all the oil veins were perfectly clean, with no sign of sludging.
But then again, there are also internal seals such as valve seals and piston rings and if they are worn, could the engine start burning oil? It is not burning any oil now.
And another concern. When I was replacing the cam seals, I saw a little bit of oil seeping through where the oil pump connects to the block. I wasn't up to the task of resealing it, so I left it alone, and I'm just keeping a close eye on it. Of course I cant see the oil pump with all the parts back on the engine, but it seems that theres no oil making its way down to the bottom of the block, everything is dry, so I assume its nothing major.
