elliotaw
- Messages
- 221
- Location
- Melbourne, Australia
Just after a little help here some1.....
I've made a new stainless steel sump for my 1uZ, its fitted up and isnt leaking (yet). ive put the oil containment right at the back of the sump close to the bellhousing to clear the crossmember on the car it's going into and so I had to fabricate a new oil pump pickup pipe.
The original pipe is about 25mm dia so I've used the same size and run the pipe right to the back of the engine and down into the oil and rewelded the original gauze filter part.
Now the engine has been sitting for about 6 months so most the oil has drained from the top of the engine and the oil pump.
I've refilled the engine and cranking it over on a battery produces no oil from the filter housing with the filter removed.
I've just tried to prime the pump by hooking up a rubber hose to the centre filter connection on the engine and filling it with fresh oil. The oil pours in the hose and then remains in the hose whilst it is held upright, so I am assuming oil has reached the pump and stopped there.
I've retried cranking the engine but still no oil coming up the pipe which is still attached.
Any ideas or help much appreciated
Elliot
Elliot
