Has anyone had the oil pump off their motor and taken some detailed pics? I want to put a prelube system on my 1UZ and am hoping the oil pump housing has a blocked port or boss that could be used for this. I need access to the suction side of the pump, where it's pulling oil up from the pickup.
Here's a pic of the 2JZ oil pump that I modified a couple years ago for the same thing. The 2JZ oil pump had two bosses that Toyota conveniently put there for my purpose. The lower, blue 45 degree fitting is coming off the suction side of the oil pump - I ran this to an external Mocal pump, then fed the discharge of the Mocal through a check valve, then back to that upper red/blue banjo fitting.
My 1UZ motor (and its oil pump) are at the builders shop which is a fair distance from me ATM, so I'm trying to do all this by "remote control" :veryhappy
